Results 1 to 3 of 3
Thread: Lengthing headlight and side light loom Defender 110
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Would adding about 10-20 cm to the front wiring loom cause issues with the electrical system of a 110 Defender? For example increase the resistance too much?
    I would like to extend the length of the wiring loom that connects the same colour-coded wire from the headlight, indicator, side repeater and parking lights into a separate bullet connector so that I just have to unscrew the headlight and be able to pull each set of bullet connector sockets out.
    With the current set-up you have to be a contortionist to reach in-between the inner and outer mudguards to be able to disconnect or connect the wires. I am a bit tired of that game of soldiers!
    Kind regards
    Lionel
    No problem - just use same sized wire minimum, not smaller.
    Ron (electronics tech)
    DiscoMick Guest
    Our Defender has an upgraded headlight wiring loom which is longer and thicker than the original and its all good.
