 Originally Posted by
DazzaTD5
				Some other mods etc to do while you have it apart...
The diff lock lever (the long one in the pic) pivots on a rubbish bitey washer, remove the rod, thread it, thin down the white nylon spacer and put a nyloc on it, tight, as it wears over the years, tighten it up as needed.
Back of the transfer case, the centre shaft that the nut in the pic is on is often loose from factory as it has not been staked enough, remove it, tap the shaft out a bit, on the other side clean it up, put a good quality sealant, tap it back, tighten nut, stake correctly.
add 2 collars to the diagnal bolts on the top shift assembly
