Results 1 to 10 of 11
Thread: Suggestions for under seat thin subwoofer location
    Mar 2018
    Adelaide
    Hi all,
    I have a Fusion CP-AS1080 8" Slim Active Subwoofer and have been looking to add it to the Disco 3.
    I feel the most useful place is probably under the middle, middle seat however, it seems to prevent the seat from folding completely flat.
    Has anyone installed something similar at all?
    Michael
    Oct 2016
    Perth, AU
    Not 100% on the D3, but why not use a 'proper' sub in the factory location in the boot?
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by veebs View Post
    There should already be a sub in the lower tailgate so if its faulty i'd replace it with the new sub.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2018
    Perth (near Malaga)
    What ^^^ these guys said, but if I were trying to install a slim sub in a sub-optimal location (see what I did there??). I'd be pulling off one of the rear boot side covers and putting it in there. If you have rear A/C then the passenger side is full, and if you have the RSE then the drivers side is full. But if you had either of those then you'd already have the factory sub in the tailgate.
    If you have the base-bass model, then either is free but then you'd also have room under the drivers (no MOST bus Amp) and passenger (no DVD/NAV) seats.
    A quick google for the manual of the model indicates it's 600 Chinese watts and 100 real watts with built in crossover, so it'll be an interesting mix with the existing sound system. I read some reviews but didn't go in too far because on-line reviews are not incredibly "reliable".
    It's going to be a serious case of "it depends" and "depending" on where you mount it. What sound system do you have in the car right now and how do you intend to hook it up?
    Dec 2011
    Adelaide
    142.79 MB
    Quote Originally Posted by swiftnets View Post
    Hi all,
    Michael
    I have a D3 poverty pack and it has a big empty hole in the lower tailgate where a subwoofer would be fitted.
    Don't know if this helps or not.
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Aussie Jeepster View Post
    SE isnt quite poverty, my SE has the base stereo and it has a sub.
    1974 VW Kombi bus
    Dec 2011
    Adelaide
    142.79 MB
    Oh really! I have the base stereo too ( or I did until last weeks replacement!) and the is no sub in mine.
    Oh well, different builts for differnt reasons!!!
    REMLR 012
    Oct 2012
    Mine is base SE stereo and no sub. Doors and tweeters only but I’ve always thought it sounds really good just in base format as handles volume well. Then again I’m a stereo luddite.
    Sep 2014
    Baldivis WA
    Mine's the SE with small monochrome screen and HK stereo, no sub. Did a Decibel Drag race with my mates HSE MY11, no real difference in dB output, no discernible sound difference either.
    If I was going to install a sub, I'd be looking for the closest size and best possible quality that would fit in the factory space in the rear door.
    Oct 2016
    Perth, AU
    Quote Originally Posted by Eric SDV6SE View Post
    Really? Sub vs no Sub and no difference?
    Did you test with 'The Chipmunks greatest hits'?
    Chipmunks - The Chipmunk Song 1958 - YouTube
