Results 1 to 10 of 16
Thread: Engine starting isuues.
    May 2015
    Williamstown, Victoria
    The car started on the thirds try this morning. Normally it starts first time every time. Battery less than a year old. I do hear a click, so I'm thinking starter motor solenoid.. or something. Any ideas?
    Build date 11th Oct 2003
    LROCV #1410
    Jan 2011
    Gippsland
    Quote Originally Posted by Bohica View Post
    If hear ‘click’ followed by no corresponding response from the starter motor then the solenoid is the likely problem - it’s an easy DIY fix costing around $30.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    May 2015
    You tube is handy, removing the starter motor does not seem that painful. Parts ordered.
    LROCV #1410
    Aug 2022
    Whyalla
    Discovery 2 starting issues
    I own a 99 d2 td5 and have been having starting issues for some time now. Just recently it was a case of definitely no go.The problem proved to be the fusible link feeding power to the starter solenoid making intermittent contact.The start relay contacts feed power via fl 12 on my circuit diagram, in reality it proved to be fl 13. The contacts of the fusible link were distorted and caused an intermittent fault .Not a problem to cure but a real brain teaser to diagnose.
    May 2015
    Quote Originally Posted by Ron B View Post
    Thanks, I'll have a look at that, The car started first time this morning and yesterday afternoon it made the sound of the starter motor engaging, then nothing. Could I have an easy fix? (Would I be so lucky)
    LROCV #1410
    May 2015
    Tonight difficulty starting.I was getting a definite click from under the bonnet, 5 or six tries until it started. I was hoping that the parts would get here before Saturday. Got home and the parts are here!
    Thanks to british4wd land rover parts hobart I ordered the parts yesterday and they arrived today. I reckon that is excellent from South Tassie!
    LROCV #1410
    Jan 2011
    Gippsland
    That’s who I got my parts from, and I also experienced prompt deliveryEngine starting isuues.
    LROCV member #131
    May 2015
    many clicks before it started this morning, I only need three more starts until I can repair the starter motor.
    LROCV #1410
    Aug 2022
    Whyalla
    Discovery2 starting difficulties.
    Quote Originally Posted by onebob View Post
    I have found the solenoid contacts burn out after a couple of years .Easy to replace ,I bought the plunger and contacts locally, they also suit Toyota Denso starters.I found the part numbers on a forum ,sorry I can't tell you which one, A kit is available with all the spacers etc. from a number of traders on Ebay.
    May 2015
    I've had the car for close to 7 years and 100k kms, a lot longer than a couple of years.
    LROCV #1410
