This sounds like a similar problem that occurs with the 4.4 TDV8 which is caused by a bad connection in the harness to the fuel pressure sensor that causes a distortion of the signal. The fix for the 4.4 is to cut out the 2 connector halves and fit a new connector and wiring tail direct to the sensor. I have a new sensor connector for when mines starts playing-up.
