Results 1 to 8 of 8
Thread: Any puma gearboxes to be found in Australia?
    Aug 2012
    North Loburn, New Zealand
    None in NZ... Ashcroft is current plan unless cheaper option can be found 😞
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
    May 2006
    Ulverstone,TAS
    PM sent
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Apr 2007
    MUSWELLBROOK
    I have a spare.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    should be no problem finding one
    the mt82 gearbox is used in commercial vehicles behind the 2.2 engine all over the world , should be simple to obtain one from any wrecking yard.
    newer ones will be in ford rangers.
    Aug 2012
    Quote Originally Posted by big harold View Post
    I have a spare.
    PM sent.
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    Quote Originally Posted by ramblingboy42 View Post
    the MT82 behind the ranger is different internally to the LR MT82. Uses different gearsets and different main shaft. Likewise the transit version of the MT82 is different internally again. I know because we stripped a ranger and transit box hoping to steal parts. You would want to compare the input shaft length, spline count and pilot whether they are the same. Likewise, would want to satisfy yourself that the tail housing bolt pattern on the case and output shaft are the same.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    Apr 2018
    Time for a LS3 4l80e swap me thinks Any puma gearboxes to be found in Australia?
    Aug 2012
    Quote Originally Posted by MLD View Post
    Yes I understand they are different too. The Ranger being Getrag stamped on the box and the Puma one isn't.
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
