Results 1 to 4 of 4
Thread: Defender 300 tdi gear stick problem
    Dayboro, Qld
    The gearstick on my 1996 Defender has gone really sloppy and first and second gear seem to have moved 200mm to the left
    Reverse gear is impossible to find, I'm about to investigate by removing the gearstick assembly to have a look but not sure what I'm looking for. Can't find much info on google
    The spring with the pin running through it isn't broken as suggested by M R Automotive
    Apr 2019
    I had some silicate the other year, from memory there was a grub screw that held a shaft in place had come loose.
    I pulled the top cover off.
    A forum member helped me over the phone while o was stuck on the side of the road.
    Dayboro, Qld
    Quote Originally Posted by W&KO View Post
    That was exactly the problem with this one, so an easy fix
    I treated it to two new gear knobs also, it now changes gear like never before
    Mar 2010
    victoria
    Syncrogearboxes.com have a few Youtube clips which may help
    Syncro Gearboxes - YouTube
    Slickshift installation
    Setting up the bias springs
