Results 1 to 8 of 8
Thread: Second Battery Threads
    Brissy! No flannos here!
    Hello,
    I need to replace my yellow top second battery.
    I have looked at many threads on the subject over the past 12mths and got some good ideas.
    Prob is, I can't find those threads now! I only seem to be returning older threads from a decade or so ago.
    I've worn out the search function so I'm probs doing something wrong.
    If y'all could point me to some of those threads so I can re-read them, I'd be very appreciative, as would my waeco!
    Ralph
    Dec 2009
    Baldivis WA
    Maybe this will help SSB HVT 50D Vs SSB HVT 65D
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Jan 2015
    and this thread is helpful too: Optima D34 Yellow top or SSB DryCell HVT-50D AGM
    I actually just replaced my HVT-50D with the HVT-70LD (HVT-50D just over 3 years old but car has hardly been driven and battery hardly charged so I can't really complain)
    As I have a bracket mounted on my Traxide tray for my compressor outlet I couldn't be bothered taking the tray out to flatten the edge, so I cut it in situ with a Dremel. It did work but I wouldn't recommend it - stainless doesn't like to be cut
    Fits nicely though. Pic below before I put the insulating terminal covers on
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Mar 2007
    South Arm, Tasmania
    Fullriver DC85-12 heavy duty AGM is another option. Tight fit, but you can get it in there. I'm very happy with this battery in mine.
    I have previously had two of the Optima Yellowtop batteries prematurely fail in the same duty and would not recommend them to anyone.
    Cheers .........
    BMKAL
    josh.huber Guest
    Neat install
    Queensland
    Quote Originally Posted by BMKal View Post
    Just be aware, that is a DEEP CYCLE type battery.
    This means it is slower to charge and should not be used for cranking the motor.
    The SSB HVT batteries are cranking batteries come deep cycle.
    This means they will rapid charge and this is a big benefit when you have large capacity alternators like those in D3s and D4s.
    Cheers All,
    I should have mentioned that my second battery and SC80 (I think) is cabled and situated in the drivers side second battery space.
    I note most seem to mount in front of the start battery. Seems similar space and access.
    Ralph
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Ralph1Malph View Post
    Cheers All,
    Ralph
    Some D4's have other gear in the aux tray hence using a tray in front of the main battery.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
