Thread: Injector leak off line - persistent leak
    Jul 2013
    Has anyone had issues with the injector leak off line to injector connection? I had a leak at injector #5 and I just finished replacing the leak off line. All was ok at the initial startup with no leaks, but the same injector started leaking again after a short run. Leak off line looks to be correctly seated in the injector and I also used a new retaining clip in this one. Going to have to pull it apart again and sort out what’s going on. Any one else has a similar issue?
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Mar 2016
    So you’ve installed a new leak off line and it’s still an issue? Mine was leaking and the Indy replaced the leak off line for that side and not a problem since
    2007 Audi RS4 (B7)
    Jul 2013
    Yep new line and leaking at the same injector again
    Shane
    Jul 2013
    So the retaining clip had come out.
    Found the diesel leak on my Disco. Not quite sorted yet... - YouTube
    Also found all the clips on the right bank where kinda loose - left bank all good. So removed all the clips on the right bank, squeezed them all down for a little more clamping force. Made sure cylinder #2 was seated correctly (the problem injector). Took it for a test drive and cylinder #2 has popped out again I don't really feel like attempt #3 to fix this issue
    Shane
    josh.huber Guest
    Quote Originally Posted by shanegtr View Post
    Is there a blockage in the line causing a buildup?
    Jul 2013
    It’s a possibility, but from past experience high pressures there will generate a fault code which I’m not getting
    Shane
    Jul 2013
    Wel I think I may have solved it (at least so far&#128518. Clip that I just removed was quite loose so I squeezed it down and refitted and although it took some effort to push on it also was quite loose when fitted. So I removed it and squeezed down a different clip, fitted that and happily it wasn’t loose when fitted. No more leaks so far
    Shane
