Thread: 107 cab window replacement
    Dec 2010
    Kiewa Valley, VIC
    Seems like I’m monopolizing this forum at the moment 107 cab window replacement….
    I’m missing the glazing in the cab rear window and looking to get some 5mm Perspex cut in town. I have a broken shard of the original which includes one only of the outer latch aluminium sections. I will need to see if I can fabricate another using the original as a guide, however have no idea what the draft stopper section looks like. Can someone post a pic with dimensions please.
    Taa
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    JDNSW's Avatar
    I'm not sure it is a draft stopper - i seem to remember it is just a U-shaped stiffener.
    Sep 2012
    Westlake ,brisbane
    These may not be of much help but may be of some use. truck cab.jpg truck cab1.2.jpg
    Jul 2009
    S.E.Qld
    These are the parts used on the cab back window. The brass knob on the catch is my addition. Originally just a bolt with some nuts was used. I believe the rubber sealing strips attached to the cab at the ends of the
    window opening are L-shaped. (I replaced mine about 20 years ago) Which measurements do you need ? Using part numbers would be helpful.
    .W.
    Dec 2010
    Kiewa Valley, VIC
    Quote Originally Posted by B.S.F. View Post
    .W.
    Draft strip 302449. What is the purpose exactly? Does the metal thickness really reduce the gap between the sliding glass sections enough to stop drafts??
    Anyway, could you tell me the width and length of this section please, I may as well make one and fit it the glass for originality’s sake.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Dec 2010
    Kiewa Valley, VIC
    .W.
    Is the original glass 5mm?
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Jul 2009
    S.E.Qld
    Looking at it from above. (not to scale)
    .W.
