Results 1 to 3 of 3
Thread: Changed transfer box now has a judder/wind up when on full lock
    Dec 2014
    Branxton, NSW, Australia
    Unhappy Changed transfer box now has a judder/wind up when on full lock
    Hey guys, I did an input bearing on my D3 transfer case the other week. I pulled the Transfer box out, rebuilt it using new bearings and seals and guided by the guide on the Range Rover forum. Took some photos along the way and I'm 99-100% sure its all went back together nicely and as it should. I reinstalled the box yesterday and filled the oil up and re-fitted all the other crap I had to remove. Took it for a test drive al went well, no more noise. Then not long after I was manoeuvring around the driveway on full lock and there was a terrible juddering noise and clunk which I'm sure is the centre diff winding up. I think I may hopefully just have to recalibrate the box, Man was I deflated when my rebuilt box started making these noises! It was also accompanied by a suspension fault but I did replace two front struts as well. Or it may have come about from the Transfer issue, not sure. Why are these bloody things so technical.....
    WRT the clutch motor on the side of the box, can anyone confirm that it doesn't need to go back on the same spline or anything silly like that? As in, can it just bolt back on in whatever position, pretty sure it can and it'll move itself accordingly. Pretty positive that everything internally went together properly.
    Current - Silver 2007 SE D3
    2005 Defender 110 Wagon TD5 - Gone :(
    Mar 2016
    Quote Originally Posted by hpal View Post
    You must recalibrate it
    2007 Audi RS4 (B7)
    Dec 2014
    Quote Originally Posted by DiscoJeffster View Post
    Thanks mate. I've been racking my brain trying to figure out what I've assembled wrong!
