Results 1 to 10 of 15
Thread: Can I borrow a torque wrench capable of 460nm?
    Jul 2018
    Essendon
    Fitting a harmonic balancer to a td5, need a beefier torque wrench than I possess. Before I go out and buy one for potentially a single use, anyone kind enough to lend me theirs? Located in Melbourne’s west, happy to compensate with beers or $
    Oct 2012
    Often there’s an alternative equivalent like 200nm +90 degrees which can be done with regular tools and a paint marker. And not to be too worried if you don’t get there exactly on these things with some loctite on the thread.
    The BMW E30 crank front bolt has a similar torque value and no one is doing it up that tight.
    And use a new bolt each time on these big torque bolts
    Geelong, VIC
    I haven’t had to do out Td5 one yet, but I’d be pretty confident that most who have done the job haven’t used a torque wrench.
    A quick calc - 460Nm comes out around 31kg at 1.5m
    Grab a bit of medium wall pipe 1.5 m long, slide it over your breaker bar and apply 31kg to the end of it (I normally use a spring balance or “fish scale” for this sort of thing).
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Bacchus Marsh Vic.
    You may be able to make an extension to use you existing wrench.
    I did this with a pipe over a breaker bar on the bolt and shifter in the other for the torque wrench, just did the maths and a few texta marks for maintaining distances.
    Torque Wrench Extension Formula
    You should find other posts using the search function at the bottom of the page.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Jul 2018
    Essendon
    Quote Originally Posted by alien View Post
    Wow that’s great, cheers!
    Jun 2008
    Drouin East, Vic
    'Two grunts and a sigh' on an 18" breaker bar.
    I was in the motor trade for the first 6 years of my working life. The only time a torque wrench was used was for cylinder head bolts, main bearing caps and big ends. And not even every one of those.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by POD View Post
    I remember helping dad when i was a teenager and i think it was about 75lbs for everything, back then most old cars used cast iron so not much risk of stripping threads.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2010
    Moe, Victoria
    I have a 3/4 Warren and Brown deflecting beam torque wrench that covers the range and would be happy to loan ... I'm about 2 hours drive from you though.
    Jul 2018
    Essendon
    Breaker bar + 1m square steel tube + pry bar + luggage scale got the job done
    Simples
    Sep 2010
    The Hills.
    152.79 MB
    18 volt 3/4" Milwaukee Fuel rattle gun...
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
