Results 1 to 10 of 11
Thread: Black stuff in the Radiator Overflow bottle
    Dec 2021
    Wamberal, NSW
    Hi All,
    I have a 2007 Disco with the 2.7 TD that has been great for the past few years and given me pretty much no issues other than a dead battery at one stage (it did set of a heap of codes that just turned out to be the battery).
    Last month I did an oil change and general service and during the service I found what I thought to be oil in the coolant bottle. Very black, sludgy and thick. I drained the bottle and found it was mainly just in the bottle and not in the radiator when I flushed it out. The oil from the service looked fine, no signs of water, nor any milky look to it.
    I took the precautionary measure of replacing the oil cooler as the disco has 230K on the clock and the original oil cooler was still in the car. Flushed again and after a week of driving (no issues, running great) the bottle has black in it but looks to be more like carbon clinging to the side of the bottle. Fluid is still clear and bright red and no signs of an oil film.
    Could the black in the cooler be from the EGR? or am I looking at a head gasket? Any thoughts here would be great.
    Oct 2012
    I had same issue and replaced my coolant bottle at same time I replaced the oil cooler and coolant. The new bottle is now lightly contaminated at the level mark. I’ve since changed the coolant again and the coolant is perfectly clean. Any crud obviously rises to the top and absorbs into the bottle plastic.
    I’ll change the bottle soon as I think it’s just a case of not fully getting rid of the oil residue in coolant after the cooler change.
    My tip is don’t immediately change the coolant reservoir. Run for a while after the change and flush and change again as only the tiniest amount of oil makes an impact.
    At that age the oil cooler is definitely toast. After that it’s only the EGR coolers but you’d see loss of coolant or other issues as a clue.
    In saying that yours is very very dark. Did you also change the bottle? There’s no effective way of cleaning the old bottles. I did try.
    Dec 2021
    Wamberal, NSW
    I had scrubbed the bottle out to remove the residual gunk, but this time is looks like carbon. Could it be the EGR?
    Might be a good excuse to blank the EGR's and complete the EGR coolant hose removal...
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by PerthDisco View Post
    I'd love to know what that stuff is. I tried acids (Sulphuric, Hydrochloric, Nitric & Phosphoric), Finish dishwasher powder (basically Sodium Carbonate), Sodium Hydroxide and plain old washing up detergent. One at a time of course.
    Next up is Trisodium phosphate and then Pirhana, and I'll give those a go next service.
    Regardless, of the chemical the bottles have so many chambers just getting it flushed properly is a mission!
    Jan 2014
    Perth Western Australia
    re soot, yes the egr heat exchange has failed internally, while i dont recommend it, while its running with the cap off you can smell the exhaust, more common on the 3.0 D4
    Daz
    Mar 2016
    Quote Originally Posted by DazzaTD5 View Post
    This likely explains my blackened coolant fresh after a change? 3.0L D4? Any way to diagnose which one given their ridiculous cost?
    2007 Audi RS4 (B7)
    Mar 2010
    Peregian beach
    I'm getting ready to change the oil cooler in my D4 2.7. All parts are here and I'll replace the water outlet (was replaced with timing belt) for good measure at the same time and have a new expansion tank as well. Will also change teh water oulet on the side of the block.
    Jobs going to be a pain and take a few flush's I imagineto get rid of all the oil but hey, has to be done.
    josh.huber Guest
    Oil floats, you can use Omo to break it down. Or you can use Cummins restore. The best way to get it out is float it out.. Make a t peice in was bottom hose and use the garden hose to push it out while the engines running.
    Mar 2010
    Peregian beach
    Quote Originally Posted by josh.huber View Post
    Cheers mate, so bottom hose where the thermostat housing is?
    Oct 2012
    Quote Originally Posted by brad72 View Post
    That side of block plastic fitting is super important and a real fight to get at. Doing the turbo hose change to silicone at same time works well because you have to take apart so much for access. You need long extensions and swivels on your 1/4” socket set.
    My tip is don’t change the bottle straight away let the new system settle down after changing the cooler for a while then switch bottles later or do a second half flush / change at same time as changing the bottle. The slightest oil stuffs the bottle quick time exactly at the high level you want to see.
    Bottles can be easily switched.
