Thread: 2005 Disco 3 TDV6 Engine Rattle
    Jun 2018
    Tamworth
    Looking for some help before I book in with the mechanic. Yesterday while driving home I noticed a high pitch rattle coming from the engine when I had the window down. No issues accelerating. Seems to be most noticeable when idling. I popped the bonnet and seems to be coming from the bottom of the engine at the front. Any suggestions as to what might be the cause?
    NSW SW Slopes
    Hopefully just the bearing in the belt tensioner is on its last legs, which if the cause will need to be replaced promptly. The whole tensioner is replaced rather than just the bearing as the pivot in the tensioner wears which causes the belt to not run true. Best to replace idler pulleys at the same time too.
    Jul 2013
    Another vote for the belt tensioner. I've had similar in the past where the tensioner part has basically failed and it rattles around. Check your belt to the alternator as you'll see it twisted (the belt that is)slightly if it's the cause
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Jun 2018
    Tamworth
    Thanks! Do you just do one tensioner or both of them? It certainly matches where the sound is coming from. Worth buying a viscous spanner for?
    NSW SW Slopes
    There's only 1 tensioner but a couple of idler pulleys.
    A couple of sharp taps with a hammer on a light-weight spanner should do the job.
    Jun 2018
    Tamworth
    Thanks for the help with the diagnosis team! It was well and truly gone and some. I ended up ordering some viscous spanners from the UK because I didn't want to stuff around. The thing that took the longest was getting the wife to put the new belt on while I swung on the breaker bar...
    St Helena,Melbourne
    4.28 MB
    Got it just in time, could have been a nasty bill if it let go.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
