Thread: 300tdi bonnet vs td5 bonnet
    Mar 2010
    victoria
    Hi,
    is there any difference between a 300TDi bonnet vs a TD5 bonnet?
    Specifically in relation to chequer plate for the middle section.
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    there is no chequer plate on a "td5" bonnet , assuming you mean a D2.
    Jun 2013
    Universe A
    Quote Originally Posted by BreakingBad View Post
    Hi,
    Functionally there should be no differences, although older bonnets are more likely to have a wheel carrier.
    That aside the TD5 cut chequer plate should be the same as 300tdi.
    Mar 2010
    victoria
    Quote Originally Posted by ramblingboy42 View Post
    No. I'm talking about adding chequer plate to the middle section of a Defender bonnet. I already have chequer plate on the wing tops. Can't seem to find the true 3mm chequer plate middle section specifically for 300tdi but have seen it for TD5.
    Mar 2010
    victoria
    Quote Originally Posted by shack View Post
    thanks,
    I do have the fittings for bonnet mount spare and realise I will have to modify chequer plate to suit.
    Jan 2010
    Defender Bonnet Protector - black - to 2007 - Paddock Spares also available in 3mm silver and Paddock's site confirms all defenders to end of TD5.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Apr 2018
    Adelaide
    Center checker plate
    I have the checker plate for the bonnet that I removed from my 1998 300 tdi so I could fit the spare wheel fittings. The four rubber supports did not have enough thread length to go through the bonnet and the checker plate. I’m happy to give away my checker plate to anyone who wants it.
