Results 1 to 6 of 6
Thread: 12v wiring, gotta scratch ya head sometimes
    Apr 2019
    I think I posted something similar a while ago……
    Thought I’d help a guy find out why his 12v wiring, gotta scratch ya head sometimes bong lights stopped working last night.
    Fuse holder melted and fuse looking pretty average….
    I found yet another example of wiring in an fuse without a fuse holder, here I was thinking the first one was a once in a life time find. He said he’d owned the 100 series for 6 years and thought it was OK as the previous owner said it was all good.
    Bloody Toyotas.
    Apr 2019
    Brisbane,some of the time.
    At least it has a fuse,i have seen many instances where a fuse is needed,but none is fitted.
    Sep 2010
    The Hills.
    152.79 MB
    In that first pic it looks more like a heater element than a fuse...
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2014
    Hunter Valley NSW Australia
    All of those spade fuses have alloy spades, alloy is prone to corrosion especially when it is mated with a dissimilar metal like brass, steel, zinc coated steel, stainless steel etc.
    The resultant corrosion means the connection heats up as current flows through it which in turn raises the resistance, which causes more heat which results in the melted fuse holder above.
    I've also had a similar problem with vehicle fuseboxes which usually have brass contacts and the heat produced has led to a fire under the dash which causes some alarm to the driver when smoke starts to pour out from under the dash!
    Oka's also suffer from the problem so make pulling all the fuses and either cleaning the fuse spades or replacing the fuses every 12 months or so.
    Another way to solve the problem to a certain extent is to coat the fuse spades after cleaning with conductive grease very sparingly otherwise dust builds up and causes more problems.
    Oct 2007
    Brisbane West
    I find the best preventative is Corosion X spray both into the holder and on the fuse. Marvellous stuff and in no way comparable to WD40 and similar. It goes on my PCBs and equally inside my spinning (fishing) reels. Cheers
