I don’t think there is anything wrong with your compressor.
I have an AMK compressor with a slightly different algorithm than the Hitachi. You can choose the compressor brand with the Gap Tool.
Max. pressure is just over 1700kpa dropping to about 230kpa.
I ran 3 cycles of Access Height to Normal Height back to back.
First cycle form a cold start the compressor reached 60c
Second Cycle reached 80c.
Third cycle reached 92c
Your compressor took just over a minute.
Mine took just under 1 min 30 sec.
Your compressor is reaching a higher pressure in a significantly shorter time so I am not surprised it is generating more heat.
So I think all is as it should be.
				MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
