Results 1 to 10 of 12
Thread: Trailer sway control
    andyandee Guest
    Hi all,
    This topic may have already been covered so I apologise if this is a boring question!
    I have recently bought a MY15 Discovery SE SDV6 and plan to use it to tow a caravan (ATM 2800kg).
    I have the option of fitting sway control to the caravan but have heard that this can interfere with the Disco's trailer sway control system.
    I'm very interested in any feedback from the AULRO community.
    Cheers, Andy
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by andyandee View Post
    Hi all,
    Cheers, Andy
    Correct you don't need it with any eas equipped LR.
    Also I will move this to the correct section.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Nov 2015
    Black Rock
    What loanrangie says. Trailer Stability Control is activated when the trailer plug is inserted. If the trailer dash light illuminates when the turn signals are activated, then it is working along with a few other smarts.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Mar 2016
    Quote Originally Posted by DieselLSE View Post
    Not exactly correct. Trailer sway is always enabled, trailer connected or not. It’s a base function of the dynamic stability control. The vehicle senses a yaw motion not commanded by steering input and uses the brakes to counter it as best as physics allows.
    2007 Audi RS4 (B7)
    Jan 2010
    Quote Originally Posted by DiscoJeffster View Post
    I thought the best way to control trailer sway was to apply the brakes to the trailer and not the car, so if one had lightning fast reflexes pushing the manual brake button on a trailer brake controller would stop sway.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Mar 2016
    Quote Originally Posted by RANDLOVER View Post
    Absolutely, and it doesn’t have to be lightening fast either as trailer sway builds up. I’m just saying how the trailer sway function works on the Disco. There’s a video somewhere online about it by them.
    I think the system would struggle to stop sway induced by a poorly loaded trailer as physics tends to get in the way.
    2007 Audi RS4 (B7)
    Jan 2010
    That makes sense as a trailer brake controller has to be installed if towing over 750 kgs., so the car has no way of braking the trailer independently.
    1999 D2 TD5 Gone
    Sep 2014
    Bathurst, NSW
    The Land Rover Trailer Stability Control will do whatever it can to keep the whole system (car + van) stable on the road. HOWEVER, one thing the LR TSC cannot do is apply the brakes on the caravan to prevent a Yaw/ Sway event. The optimum thing to do in the event of a caravan yaw event is apply the caravan brakes asap. This is why having a system ON THE VAN, such as Alko ESC is highly desirable, as it will apply the van's brakes quicker than you can ever respond. Having ESC on the caravan will not impact the Discovery's computer system (TSC). The TSC will only ever respond to what the van is doing and apply the cars brakes or cut power, based on what is being detected. Both systems will work in concert. IMHO, you'd be crazy not to get ESC on the van and just rely on the Land Rover TSC to stop a van swaying.
    2014 SDV6 SE, Fuji White, ARB bar, Fyrlyt 5000, Pioneer Platform, Traxide D4-5S, Maxxis 980 Bravo, GOE Compressor Plate, ICom-450 UHF, Red Arc Tow Pro.
    Elite Murray 2 Caravan 24'4" Tare-2917kg, ATM-3500kg
    Nov 2015
    Black Rock
    Might be, might be, I don't know. This is what the workshop manual says:
    Trailer Stability Assist
    When the trailer electrical socket is connected, trailer stability assist operates automatically to enhance the existing
    DSC and terrain response functions of the vehicle when towing. The system detects sway movements caused by
    trailer oscillations at speeds in excess of 60 km/h (37 mph) and acts to eliminate them. It does this through braking
    and engine management. Braking management counterbalances the sway movement through symmetric and
    asymmetric braking, thereby slowing the vehicle and eliminating the oscillations. Engine management adapts engine
    torque output to support the braking management in stabilizing the vehicle and trailer.
    Typical conditions when sway can occur include:
    Changing highway lanes.
    Traversing a lengthy bend.
    Acceleration.
    Braking.
    The capability of trailer stability assist to respond early to the beginning of trailer-sway makes the system almost
    unnoticeable under normal driving conditions and keeps the vehicle and trailer under safe control. Trailer stability
    assist requires no input from the driver and operates up to the maximum vehicle speed.
    Trailer stability assist will not operate while DSC is switched off.
    Mar 2016
    Land Rover Trailer Stability technology - YouTube
    “.. and does not require the trailer electrics to be connected Trailer sway control…”
    As most have their trailer connected and being sensed correctly, the issue is moot anyhow.
    2007 Audi RS4 (B7)
