Results 1 to 10 of 13
Thread: Component that allows gearbox change from Auto to Sports Mode.
    Jan 2023
    Burrum Heads QLD
    Can any skilled person advise me how to repair this following problem.
    My concern is my LR3 Diesel Auto no longer allows the change from Auto Drive to Sports (manual) change. The vehicle drives superbly in Automatic mode but now, does not allows the selection to sports/manual mode via the gear change selector.
    The gearbox was completely refurbished nearly 30,000 kms back at a costly sum, I’m considering the outer mechanism (s) were not changed as they were not defaulting.
    My closest Experienced gearbox repairer is 3 hours drive from me, hence my call for assistance etc. TIA.
    Jun 2013
    Universe A
    Quote Originally Posted by 11vamp View Post
    So what happens when you try to go to manual?
    Anything display on the dash?
    Is sport mode working ok?
    FYI, LR3 is the designation used in North America. For the rest of the world it's Discovery 3, Disco 3, or D3. We can't have those pesky Yanks changing everything!
    Oct 2011
    Fremantle WA
    Technically you are right, but perhaps a tad pedantic towards someone genuinely looking for answers?
    NSW SW Slopes
    If this problem has existed since the gearbox was overhauled then perhaps the selector cable might not have been correctly adjusted when the gearbox was refitted. Otherwise the gear selector module may have developed a fault.
    St Helena,Melbourne
    4.28 MB
    This issue is likely caused by a fault in the gear shifter , there is a PCB on the side of it that controls sports mode and command shift.
    In my case my console got drowned in a summer downpour and the PCB was fried, I had to replace the whole shifter and a short wiring harness that connects to it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Quote Originally Posted by gavinwibrow View Post
    You're right - it was a bit brusque. I've edited my post. Hopefully it's a bit more betterer.
    Jan 2023
    Burrum Heads QLD
    Reply to shack
    Quote Originally Posted by shack View Post
    Shack, thank you for your interest, when changing to sports mode, being stationary or underway, nothing happens apart from the position of the gear stick, the vehicle remains in auto mode and transmission fault remains on Dash board. Drives all good but does not change. Any help appreciated.
    josh.huber Guest
    Micro switch under the gearstick cover?
    Mar 2018
    Perth (near Malaga)
    I don't think you mentioned that previously. That'd do it. Need to get codes out to see what it thinks the fault is.
