Results 1 to 10 of 15
Thread: Winching. Will this work?
    Queensland
    I am busy fitting a remote control to the mid mount hydraulic winch on my camper.
    Thinking of this idea to enable me to pull from the front but cant quite envisage what the strop cable will do when winching in.
    The winch cable will run through the 3 blocks to get around the body , then I wanted a strop with a snatch block to direct the pull forward.
    Should the strop be shorter or longer?
    Or will it under the influence of the cable pulling in just get pulled in also until it jams against the front LH corner block.
    Nothing is new so this has probably been done before but I cant try it untill I get my truck back together.
    Any ideas?
    Apr 2019
    As the snatch is floating it’s going mover toward the corner……
    You could probably simulate using a piece of rope.
    What vehicle are you fitting the mid mount winch to??
    I like the way Eric did his on THE109….1:1 pull backwards and 2:1 forwards, Cable running down the inside of chassis.
    Apr 2019
    Oh me thinks a shorter strop will get the cable closer to centre of vehicle
    Oct 2020
    Elizabeth North SA
    3.15 MB
    Quote Originally Posted by W&KO View Post
    Yep, a nice short strop to only reach the centreline. Any reason you can't put another block in the middle to centre the line ?
    Sep 2010
    The Hills.
    152.79 MB
    Not sure I'm seeing this. IMO in both those diagrams the strop will do precisely nothing. Diag A will get closer to the desired result, but it's still too long. I'd be inclined to have a fourth block at the centre at the front. The military MK3 trucks had a central winch, the cable was routed under the vehicle rather than around it. Not sure you could do that on a 101FC.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Queensland
    Yes my thoughts are along the same lines but I thought the strop my negate the need for top and bottom rollers.
    I can fit another block on the centre line but just trying to save another 90 degree angle.
    I might see if I can fit a bridle underneath with the snatch in the centre and under the bull bar. Same thing as a centre block but wont need rollers as the bridle can move vertically to allow for vertical pull angle. The bridle would be shackled to the front end of the chassis rails. That should work eh?
    This is for my old 2A Fc camper.
    Keith
    Jun 2008
    Drouin East, Vic
    I'm not sure it's necessary to get the line pull close to the centreline of the vehicle. With the Inter army trucks, the cable was brought from back to front down the chassis rail and a fairlead at the front of the chassis rail.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by POD View Post
    I remember it well...
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Queensland
    Yes I had that on the 6x6 camper I built but I dont have the space on this old girl.
    I have had the winch on it for 30 years and its never been used in anger. Its just I am getting older and weaker and may need all the help I can get.
    I think I will go for the bridle idea. Saves welding up a roller box and is not extra weight on the front. Only shackle it on when needed , hopefully never.
    Mar 2010
    victoria
    I've watched a few videos on winching backwards from the front mounted winch which I think would be similar to what you want to achieve.
    Anyway, I think the most forward snatch block should be as close to the winch anchor point as possible, and the winch hook joined to an equaliser strap to ensure even pulling.
