Results 1 to 6 of 6
Thread: temp sensors on a tdv6
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    how many temp sensors are there on a tdv6 and where are they located ?
    TIA
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Mar 2018
    Perth (near Malaga)
    Oil temp in sump
    Coolant Temp in top hose
    Air temp in intake elbow
    Fuel return temp in return line in the V.
    Jan 2010
    The fuel temp. sensor seems unlikely to fail as my indie had never seen one go until mine, a couple of days ago. On the scanner it was erratic and would drop to 40 degrees, and was leaking up the inside of the sensor and out the plug at the top which might explain the erratic readings, my indie thinks it might be due to the biodiesel, perhaps eating the glue/resin they use. Could be a blessing in disguise as we've been chasing a leak on the top of the motor for a few weeks, thought it was the fuel cooler at one stage.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Mar 2016
    Ambient temp sensor in the mirror
    2007 Audi RS4 (B7)
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Thanks for the replies
    Oct 2012
    That fuel return temp sensor is open to some abuse in removing the air intake which it clips to. Breaking the clip happens very easily which could plausibly crack the body and lead to other problems.
