Thread: Noise and fault codes
    Good day all
    Came back from the snowies on the weekend and now we have a new noise, listen to attached Ipone audio file.
    James Ruse Drive.m4a - Google Drive
    I'm also getting the follwoing error codes, cleared them and they were back an hours drive later
    tachometer drive open load
    gearbox / abs drive open load
    mil lamp drive open load
    glowplug lamp drive open load
    To be honest I've not hit google yet...
    Quote Originally Posted by TheEntertainer View Post
    Good day all
    Neither my phone nor laptop can play the Apple MPEG4 file... however the following might be relevant from Dr Google
    check out What is the open-load detection function available with low-voltage IPDs? | Toshiba Electronic Devices & Storage Corporation | Asia-English
    " The purpose of open-load detection is to detect a bad contact of a connector or a broken wire in a wire harness connected to an electronic control unit (ECU).
    There are two major types of open-load detection:
    The output terminal voltage is monitored while the output transistor is off. An open load is signaled when the output voltage exceeds the programmed value.
    The current flowing through the output transistor is monitored while it is on. An open load is signaled when the output current falls below the programmed value.
    Most of Toshiba’s IPDs for high-side applications use the above type 1 to detect an open load by monitoring the output terminal voltage while the output transistor is off.
    All of which might point to a loose multiplug....
    Looks like its either the throwout bearing or input shaft on the gearbox :-( according to the mechanic in wilton (great bloke).
    Time for a gearbox overhaul
    Should I park the car and not drive it at all?
    St Helena,Melbourne
    4.28 MB
    Vehicle might help for any useful help.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Any recommendations on who can do a gearbox overhaul, preferably towards picton just in case, my mechanic is normally booked out well in advance.
