Results 1 to 10 of 14
Thread: Auto Transmission Flush on High Milage Vehicle
    Dec 2019
    Hi Guys,
    Talked to a Rover guy the other day and they said there is a risk in changing the fluid on vehicles with high kms - mine has done 200km. He said that if it hasn't been changed there is a risk of dislodging debris that can clog things up.
    What are people's thoughts on this? At 200km I think the risk of not changing the oil and filter is probably high as well?
    St Helena,Melbourne
    4.28 MB
    200K isn't what i would call high but yes there is a risk of making it worse or just not doing anything, i did mine at about 170k and it didn't help with my issues.The ZF box will be on the downhill slope unless its had regular fluid changes previously.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Hunter Valley
    What I've found is that the sealant on the separator plate starts to breakdown when oil is changed on high km transmissions and blocks the solenoids. Now I change the separator plate when doing the oil change. I usually install a zip kit also, while I have the metatronics apart as the accumulators will be worn out
    It doesn't leak oil, Its sweating power
    Nov 2018
    Hobart, Tasmania
    Quote Originally Posted by Screamingkiw View Post
    Hi Guys,
    Yes, I recall about 5 yrs ago the local LR Dealer told me they experienced problems changing the oil when it was very old and not been changed regularly. It introduced some slippage.
    If I were in your position I'd be inclined to take the risk and change it. There is a product called Dr. Tranny which many people on this Forum have used successfully.
    I used in in my son's D3 which had a slightly slipping TC and it fixed it for some time. He sold the car about 30,000 klms later as he needed a Dual Cab ute, but the tranny was still functioning well.
    FWIW I use Penrite BMV auto oil and have had excellent results for past 80,000 klms. Much cheaper than ZF oil.
    Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
    Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
    May 2014
    Point Cook, VIC
    I would be getting advice from a ZF transmission specialist.
    The advice you have been given is consistent with old school thinking with automatic transmissions - either change the fluid regularly or not at all but then be prepared to change out the transmission.
    But transmissions and oils have improved a lot since then (and cost a lot more to rebuild or replace if you don’t look after them).
    If you did go ahead (and I probably would), consider getting a double flush. And with the Penrite BMV oil sounding like a good viable alternative you could do a double flush now, then run it for another 10-20K, and repeat.
    But first - see what a ZF specialist has to say.
    Jun 2021
    GRINDEWALD TASMANIA
    Auto Fluid Exchange
    I purchased a D4 with no identified service history with 120K on the clock. Amongst a long list to address the lack of servicing I exchanged the auto transmission fluid and filter. I used components available on Fleabay and Penrite fluid. No problems were created doing this other than I had to over tension the pan fasteners to provide a leak free result.
    There is a level of difficulty to remove and refit the pan fasteners, with some dexterity it is doable without removing the cross member.
    I will admit I was naïve regarding possible damage to the transmission as a result of this action however the benefits I identified out weighed the possibilities of damage. My intent is to duplicate exchanging the fluid every 50K.
    If you proceed ensure you comply with directions to fill the transmission to the correct level.
    Dec 2019
    Quote Originally Posted by Discodicky View Post
    Thanks for the info, I'll give Dr Tranny a go. It's Mardi Gra in Sydney tonight, I wonder if Dr Tranny will have a stall there?
    St Helena,Melbourne
    4.28 MB
    Lots of trannies, doubt any are real doctors though
    If you dont have any shuddering then i wouldnt put in dr tranny in, i bought some but having 2nd thoughts about using it since my issues are elsewhere in the trans.
    1974 VW Kombi bus
    josh.huber Guest
    Hi Guys,
    I doubt it. I mean, autos don't generate allot of contaminants, worst case scenario would be another filter change earlier then expected. All you can clog up is the filter. Worse off. Don't change the oil.. You are guaranteed issues
    May 2014
    Point Cook, VIC
    Dr Tranny is more of a Hail Mary - so wouldn’t use unless you are getting shuddering problems.
    When you get to the point of needing Dr Tranny I guess that is when you start saving up for a rebuild.
    And if you do spot Hail Mary and Dr Tranny in the parade tonight, tell them the Disco Fanboys send their love! Auto Transmission Flush on High Milage  Vehicle
