Only if high mileage or doing a rebuild.
I know the engines both need timing belt changes, but is the oil pump update needed on the 3.0 engines or just the 2.7's?
I'm looking at a replacement for my D3 and I see lots of mention of belt changes, but no mention of oil pumps!
And yes, I'm coming around to diesel!!!!!
Alan
2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
The 3.0 did not have the oil pump issue as it was resolved in the 2.7 run.
The only reason you need to replace the 3.0 oil pump is if it has low oil pressure, it has high mileage and or it is just prudent to change it. Some change with each cam belt change as the additional cost is relatively small with the front end pulled apart.
There seems to be an even better oil pump out there, not sure if it is just the latest model or really is something special.
UPGRADED LANDROVER OIL PUMP 2.7 TDV6 / 3.0 TDV6 - Triumph Rover Spares
2005 D3 TDV6 Present
1999 D2 TD5 Gone
That is an aftermarket pump - with these I like to go genuine Ford for less than half the price of that one.
latest FordMoCo has a 15mm impeller as opposed to 13.5mm. Might help the oil pressure being maintained a bit.
My old D3 is getting timing belts etc done and will get him to fit the new FordMoCo oil pump I got in from Poland. Donating the crank seal tool I had machined by a mate to him.
I’ve been down this road with my 2.7 TDI, so I can share what I learned. The timing belt change is a must on both the 2.7 and 3.0 engines, but the oil pump issue seems to be more common with the 2.7. When I replaced the timing belt on my 2.7, I went ahead and upgraded the oil pump since I’d heard about potential failures.
