Results 1 to 6 of 6
Thread: Steering Jitters
    Dec 2022
    Coolum Beach, Queensland
    Steering Jitters
    Hey,
    New here I have skimmed but probably blind.
    I picked up a TD5 110 and working my way through, bits and bobs, but stumped what might be causing the steering gitters.
    I have checked and done:
    • Wheel Alignment / balance
    • wheel bearings
    • Drop arm and Track rods
    • Damper Bushes
    • Prop shaft looks and feel good while under car
    What have people done to solve?
    Attached is image of rig cause why not.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    worn panhard rod bushes will give you a shimmy in the steering. I've flogged out many panhard bushes. The worst i experienced was at 60 kph the steering wheel violently shook to a degree that you couldn't hold the wheel. If it sped up or slowed down it went way. Also had it at +/-80kph. Next after that i'd check the radius arm bushes. The 60kph experience was a combination of panhard and radius arm bushes. One fed into the other.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    Gitters? Jitters?
    Lebanon
    Check also the swivel pin preload on both swivel pin housing.
    Dec 2022
    Quote Originally Posted by MLD View Post
    Described exactly at 60-80 clicks is where it’s at but only when steering is dead straight.
    Ordered some bushes so will have a look thanks.
    JDNSW's Avatar
    Possibly could be radius arm bushes, and perhaps incorrect toe out, or maybe bent axle housing. And the other likelihood is that it is a combination of factors - fix one and it goes away, but comes back soon, when one of the other factors gets a little bit worse.!
    The fact that it is only in the straight ahead steering position does raise the possibility that there are grooves in the swivel bearing races in the straight ahead position, so that there is no preload in this position.
