Did you replace the wheel bearings? If so check the bearing shells are pressed home.
Also I recall there are a variety of shim washers available to adjust the end float of the drive shaft/circlip, but you cant fit clip even with no shims.
The drive flange OEM paper gaskets are thin, and the aftermarket gaskets are much thicker. That could account for a little loss of end float
