Results 1 to 8 of 8
Thread: EGR Valve Cleaning
    Jun 2021
    GRINDEWALD TASMANIA
    EGR Valve Cleaning
    I wonder if this is a viable option prior to these components failing. Replacements units come at a premium price, I am aware there are major labour costs involved in the removal and replacement process.
    It appears that the electrics are not the reason for failure, carbon build up resulting in valve seizure or worse case scenario the valve separating from the shaft.
    Having been through the experience with a Tojo Hilux of manifold removal and EGR valve cleaning using multiple doses of oven cleaner and mechanical abrasion I wonder whether the same process could be applied to a Disco.
    Reading the posts on EGR blanking has resulted in confusion. Could someone identify what would be required to blank the EGRs on a 2014 Discovery VIN SALLAAAN5A738234 and whether there is someone in Tasmania with the ability to do the required remap.
    St Helena,Melbourne
    4.28 MB
    I can't see why not, I have the old ones that came with my car and they were coked up so as long as they work electrically cleaning should help.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2021
    GRINDEWALD TASMANIA
    Options Limited For Blanking EGRs Confirmed
    BAS Re-maps
    Chat transcript
    Thanks for chatting with us!
    This is your chat history with BAS Re-maps - keep it for your archives.
    Hi I would like to blank the EGR valves on my 2014 Discovery 4 TD6 VIN SALLAAAN5FA738234. Please advise the process to achieve this I am located in Tasmania, Australia. Thx Graeme
    Hi
    Sorry we do not have a remote solution for egr blanking on that model.
    We would need your engine Ecu here in the Uk on the bench for programming
    Admin sent this
    Looking for a way to contact us?
    Call Us
    01133280285
    Your conversation is still available online.
    You received this email because we automatically send transcripts of chats you (may have) finished.
    • © 2023 BAS Re-maps, all rights reserved.
    Mar 2018
    Perth (near Malaga)
    FedEx 2 days each way.
    Having said that, I'm sure there is someone closer who can do the job.
    Apr 2012
    Whyalla, SA
    Old Jaguar (Cambo on here) has agents in multiple Aus locations - he can help you.
    Jun 2021
    GRINDEWALD TASMANIA
    Options to Insure Vehicle Reliability
    What are owners thoughts on ECU remaps to boost performance on the TDV6. Following advice that has been posted regarding Australian ECU Programmers I have been informed that there is as much involved in disarming the EGR Valves only as incorporating this process in conjunction with a performance remap.
    I have located a programmer who will do the EGR Valves disarming only, however there is a financial incentive to combine the process with a performance upgrade.
    Based upon owners experience is there a greater possibility of crank and manifold failures by pursuing higher performance.
    Presently I am finding the standard performance spec for my vehicle adequate for my needs even when the caravan is attached.
    Appreciate recommendations.
    May 2014
    Point Cook, VIC
    EGR Valve Cleaning
    I see you are located in Tasmania Gravy - so unfortunately looks like Cambo at OldJaguar doesn’t have an agent there who can help.
    Yes doing a remap at the same time makes sense - but probably best to limit the retune to 600Nm (assuming you have the base spec 530Nm version).
    I can’t comment on if this increases the chance of a cracked manifold - I guess it depends on how you use the available power. Cambo also does a mod to use the EGRs to open when you come off full throttle to drop the manifold pressure quicker.
    Who is proposing to do the work for you and for how much?. Others may have experience with the proposed tuner and their remaps.
    Jun 2021
    GRINDEWALD TASMANIA
    Anyone Had Experience Using Eurotorque Performance Tuning
    One of the firms I have contacted. I have also contacted Cameron Knight who has quoted similar pricing however he has not offered the EGR delete only.
    Interesting that to just purchase new EGR valves from the UK would be the same expense. The labor component to fit new valves is reasonably complex, still have polluted combustion mix and the performance will be unchanged.
    Hi Graeme,
    Yes, we can do that.
    EGR ECU delete would be $600. Stg1 performance remap $1195.
    If done together I discount to $1395.
    As you would be sending the ECU in, I can reduce to $1095 plus any return postage.
    I can do the same day I received and send back the next day.
    Thanks,
    Grant.
