Results 1 to 6 of 6
Thread: Oil Change on 2015 SDV6
    Apr 2023
    Hi Guys,
    Fairly new to the World of Disco....
    Just wanting to check that we don't have a variable oil pump or similar that will struggle to pick up if the sump is completely drained.
    Nick
    Oct 2016
    Perth, AU
    No idea, but I can say that if there is no oil in the sump, it will struggle...
    Oil changes don't need you to bleed the system - on my 3.0L, I use the extraction tube to suck old oil out, change the filter, then add fresh oil in. Adding the same amount i pulled out, then checking the level display to see if i need to top up at all. All the while keeping an eye on the 5.7L capacity (ie, I don't throw 6L in, even if the screen reads a touch low)
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Mar 2016
    No issue with oil pickup on the Land Rover engines.
    2007 Audi RS4 (B7)
    Sep 2021
    Melbourne, Caulfield South
    137.03 MB
    LR Time on YouTube is well worth spending time watching.
    I followed his advice to drain the oil on my 2014 D4 TDV6 by removing the oil drain plug. The refilled oil has to pump up into the empty oil filter on top of the engine on the first restart, whichever method you use. No issue with priming.
    Also powerfulukltd has some tips but is sometimes ... not so good from a quality engineering perspective.
    Discovery D4 (L319) 2014; Tuffant Steel Mk1, Maxxis AT811 265/65, APT compressor guard/sliders/transmission-guard, ARB Summit BBar, X76 UHF, Autosafe barrier, Rijidij carrier, Longranger 74l aux tank, Darche Streamliner 1250 RTT.
    Apr 2023
    Thanks Guys,
    Had her up on the hoist for a good few hours on Saturday filled and dumped the oil until it was like new (probably 4 times)
    Would have loved a dipstick instead of sitting waiting on the electronic oil level.
    84 month Service kit is on the way so we'll get to do the belts etc.
    Appreciate the help
    Nick
    Apr 2023
    Quote Originally Posted by ScottLS View Post
    I'll check that one out
    Saw the other one relating to the oil beforehand to see how to get into the oil level display
    Cheers for the response!
    Nick
