There is better stuff than Loctite to prevent oil leaking. With 490Nm of torque on the drive shaft nut I can't see any slippage. Still I bought the Loctite to do my rear hub.
Putting new rear axles in the D2.
I was going to grease the splines to stop them seizing, but decided to check RAVE to see what is suggested.
It says to put a 3mm bead of 640 Locktite around the start of the spline which will then push the Locktite along the spline when fitting hub.
Anyone know the reason for this? I can only see 2 reasons. 1/ to prevent oil leaking down the spline. 2/ To prevent spline wear from a minute bit of back lash on the spline,
due to it being a push fit, not a press fit.
Anyone not used Locktite doing this, or used something else?
Dave.
I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
1983 RR gone (wish I kept it)
1996 TDI ES.
2003 TD5 HSE
1987 Isuzu County
Build date 11th Oct 2003
LROCV #1410
So what do you suggest I use on my D2?
I shopped around this morning and the only Locktite 640 I could get was a 250 Ml bottle for a bit over $400.
I have a 50 mm bottle coming from OS but this will not arrive until mid June.
Would it be ok to just use grease and then when I get the Locktite I remove clean and apply?
Dave.
1996 TDI ES.
2003 TD5 HSE
1987 Isuzu County
LROCV #1410
RAVE says 640. Had a look at 648 specs. It is very similar to 640 with one problem. It cures in 3 minutes, where as 640 has hours.
Rave says that the hub nut has to be tensioned before it cures.
Dave.
1996 TDI ES.
2003 TD5 HSE
1987 Isuzu County
I followed this advice and did not use any Loctite. Just a slight slight smear of anti sieze or grease.
Hub nut - why is it so tight?
Im pretty sure JC follows this practice as well. Will update if I can find the post.
I have replaced both rear hubs, tightened the hub it to spec and staked it. No problems in thousand of km.
