Results 1 to 10 of 17
Thread: Suspension fault from slightly spirited turning
    Sep 2013
    Hi
    Seeking advice - I do have a gap tool but it is currently pretty unreliable on android.
    This has happened three times - suspension when I introduce more that normal body roll. Say a quick entry to the other lane from a side road. Error goes away after a few minutes.
    This is a new behaviour. I am guessing it has something to to with sensors (presumably height or something more sophisticated.).
    Presuming many people know the shortlist to look at!
    Thank you
    Apr 2012
    Whyalla, SA
    Without codes we’d all be guessing.
    Mar 2016
    Borrow someone with an Apple device and use the GAP tool on the car and let’s get some info
    2007 Audi RS4 (B7)
    St Helena,Melbourne
    1.13 MB
    Should be no issue using the GAP app on android , i use it on my phone and tablet.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2012
    Whyalla, SA
    Have you updated the Gap tool firmware recently?
    If you haven’t used it for a while and your OS has updated you can have problems.
    Sep 2013
    I had the fault again tonight - not cornering and no change in faults. Maybe I just need a hard reset.
    Apr 2012
    Whyalla, SA
    Looks like the temp sensor on the compressor may be playing up.
    Sep 2013
    A quick google only yielded an eBay option for a compressor temp sensor overhaul kits don't include the sensor so it looks like a new compressor?
    Will check the connectors when it stops raining.
    May 2014
    Point Cook, VIC
    Quote Originally Posted by ontheway View Post
    A quick google only yielded an eBay option for a compressor temp sensor Suspension fault from slightly spirited turning overhaul kits don't include the sensor so it looks like a new compressor?
    Don’t throw parts at it yet - check wiring and connectors and if you can’t see anything obvious, clear all faults, re-scan to confirm no faults present, then wait for the fault to occur again and immediately re-read faults to see what came up again.
    Is it a D3 or D4?
    Sep 2013
    Quote Originally Posted by DiscoDB View Post
    Is it a D3 or D4?
    Thanks, more investigation.. I have 8 weeks to fettle it out before the next trip anyway so plenty of time.
    2013 L320 - before @Tombie's better half went to the SWB side of the force, the L320 forum was very quiet.
