Results 1 to 10 of 16
Thread: New Battery Test
    Nov 2015
    Black Rock
    New Battery Test
    Picked up a new SSB HVT-70LD yesterday and tested it when I got home. I have a Bond Battery tester which I've had for close to ten years and I regularly check my batteries.
    Results were:
    Rating: 620 CCA
    Measure: 434 CCA
    Volts: 12.76
    Internal Resistance: 5.16 mOhm
    Life: 55%
    Put the battery on the CTEK charger overnight and this mornings results were:
    Rating: 620 CCA
    Measure: 463 CCA
    Volts: 13.09
    Internal Resistance: 4.83 mOhm
    Life: 63%
    I reckon this battery has been sitting on a shelf for a while.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Apr 2012
    Whyalla, SA
    Yikes! I take it that one’s going back to the store…
    Nov 2015
    Black Rock
    Just emailed them. Will be interesting to see their reply. But, yes, it will be going back.
    Queensland
    Hi Diesel and that is not surprising.
    Most batteries sit on factory outlet shelves for months before being sold.
    So mild supination is going to occur but it is reversible.
    Wait and see what reply you get, but most "NEW" batteries require up to 30 charges ( not full cycle ) before they reach their full charged state.
    It you charged that battery all night, every night for a week, I'll bet it will be up to 100% by then.
    Jun 2013
    Universe A
    I've been thinking of giving this a go with a few I've got lying around.
    I think I'll put the auto charger on a timer, and set it to the lowest amps I can.
    Is that a good theory?
    Mar 2016
    2007 Audi RS4 (B7)
    Queensland
    Quote Originally Posted by shack View Post
    YES.
    Have a look at the link below to see how to get the best results.
    Scroll down the page till you get to “Battery Maintenance”
    https://www.aulro.com/afvb/the-verandah/246755-line-auto-electrical-info-8.html
    Brisbane,some of the time.
    Tim,my Cteck charger has a regen mode.I notice in the manual it says the voltage may reach up to 15.8V during the regen process.
    Can i leave the vehicle connected to the charger during the regen mode or is it better to disconnect it?
    I have never used this mode,have an AGM aux and a Lead acid starter,not an LR,both batteries are 2 yrs old.
    TIA
    Nov 2015
    Black Rock
    Quote Originally Posted by DiscoJeffster View Post
    Yep. How did you get a video of me fixing it? Did you like my OHS approved safety thongs?
    Queensland
    TIA
    The recondition mode is not good for many types of AGM batteries.
    The slow, low current cycling maintenance process is far gentler and safer for all battery types. It does take a lot longer, but usually does a much better job.
