Thread: Fuses and relays in Battery box - Defender 130
    Jul 2020
    Mount Eliza
    Can someone tell me what the fuses and relays in the battery box of my 196 Defender 130 might be for. I have worked out that some of it has to do with the air conditioning but without ripping things apart I was wondering what the rest of it might be for. It's just a general question as everything seems to be working OK - at the moment.
    Thanks in advance.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    They are not factory, so any answer from the forum is just a guess at best. You need to trace the cables to the load.
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    TonyC is offline Wizard Silver Subscriber
    NE Victoria
    32.83 MB
    Most of it is the Aus fitted AC.
    The Narva relay on the right, and maybe the circuit braker on the , left, I don't think is part of the AC
    Mine is a mirror image of yours.
    My understanding is the the AC was an Australian spec setup, that I assume was fitted by dealers and the install is a bit different car to car.
    Here is mine.
    The circuit breaker and solenoid on the left are not part of the AC.
    Tony
    Jul 2020
    Mount Eliza
    Quote Originally Posted by TonyC View Post
    Here is mine.
    Tony
    Thanks Tony. Yes - it all makes sense now - except for the additional relay on the right.
    I have just found a copy of some circuitry that has been floating around on the interweb for a while that matches the setup - so I'll use that to trace and check everything. There are two wires connected to the battery that will fire everything up when the ignition is off but the system does not work when the ignition is on - so I suspect a relay is being uncooperative.
    Jul 2020
    Mount Eliza
    Quote Originally Posted by MLD View Post
    Thanks mate - I think I may have found some circuitry that matches the layout - see the next post for a copy. I all seems to be related to the after market aircon.
    Ade
