Thread: Oil leak
    Dec 2020
    sydney
    Oil leak
    Hi guys
    I have a disco 3 2006 diesel and the engine seem to be ****ing out oil, the mechanic seem to thing it could be coming from the crank shaft seal or cam shaft seal.
    Has this happened to anyone else?
    Oct 2012
    Oil leak
    Yes it has happened typically due to incorrect installation of a new seal.
    It’s a very specific seal with a special installation technique and method that needs to be followed.
    Most likely the lower oil pump crank seal but you’ll see immediately the timing belt cover is removed.
    Make sure you have the latest oil pump if you disassemble that far to replace this seal. It’s another $300 well spent. In fact, it is mandatory for early D3s you have the updated oil pump to avoid engine failure.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by PerthDisco View Post
    X 1000
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Yes I totally agree, if the seal isn't put in the right way and doesn't get crimped while fitting.
    As I have been told by Mario, when customers use to ordered the seal from us.
    You have to be careful when fitting them. Heather
    Dec 2020
    Diamond Creek, Vic
    I agree with all the previous posts. Once the crankshaft seal starts to leak it can very quickly progress to a total oil loss with catastrophic results for the engine.
