Results 1 to 10 of 16
Thread: Wheel nuts - fit dry, or with neversieze?
    Dec 2011
    Adelaide
    142.79 MB
    I'm going to be changing my wheel nuts over this weekend to Tuffant solid ones.
    I'll torque them to 140nm which I believe is the right figure.
    But I have a question.
    I've seen others say they squirt the studs with WD40/CRC, and other use Copper Eze or Permatex Anti-Seize - is this a good idea? I know in the UK salt on the roads causes major grief, but as we dont have that issue here, is it ok to just fit them dry, and check them every 50km or so to make sure they stay torqued up?
    Alan
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Brisbane,some of the time.
    Here we go again.....
    I grease them,light smear,but others say dry.
    I usually use engine oil on wheel studs. Whether one should reduce the torque setting - I don’t know. I doubt the factory uses dry threads on the studs and nuts.
    I put anti-seize on the centre hub to stop the alloy rims corroding onto the hub.
    Apr 2016
    Country Vic.
    I use anti seize.
    I think part of the problem is that they self tighten as you drive ... not just the possibility of rust salty environment, but that they are down low on the vehicle and that's usually the most prone to moisture. I know this sounds obvious, but any moisture on steel and it rusts over time.
    Also, do you go to beach areas? Do you drive through deep water etc?
    If you don't regularly check them, like myself, then over time, a bit of rust and the self tightening issue just makes it harder for no reason. anti seize just helps at some point down the road.
    The worst vehicle I've had to deal with with wheel nuts/studs was the old International C1300 truck my father had for his delivery business. Diabolical when it came to studs, they would always snap not having touched them at all, and for sure would snap in many instances when removing wheel. One time I recall needing to change a front tyre and of the 8 studs 3 snapped trying to remove the nuts.
    I dunno about spraying with WD type stuff tho, got to be careful not to get any overspray on the disc of course. A dab of anti seize is no issue, and in the years I've done it never seen any of the issues that some propose.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Sep 2010
    The Hills.
    152.79 MB
    Like Paul says, here we go.....
    D2s have the same issue. I don't oil the threads, and have never seen the practice*, but I def use anti seize between the wheel boss and the hub, and the outside of the nuts.
    * Not saying it's wrong, Ron.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jul 2009
    S.E.Qld
    Just ask yourself why there are so many Series vehicles with broken missing or loose wheel studs, and then decide for yourself.
    .W.
    My experience with over sixty years of driving four wheel drives is that unlubricated studs will seize sooner or later. I don't think it makes much difference what lubricant you use. i usually use anti-seize, but will use any available oil if necessary.
    How essential it is will depend mainly on how humid the environment is.
    Quote Originally Posted by B.S.F. View Post
    .W.
    Well don't keep us in suspense - why?
    May 2014
    Point Cook, VIC
    You actually need to know the grade of the stud to know if adding a lubricant will lead to over-torquing at 140Nm. The typical accepted clamp force is based on achieving 75-90% proof load and this is dependent on the grade of the bolt (stud in this case) and the thread coefficient of friction (dry or lubricated).
    Unfortunately the studs have no grade stamped on them, and the only individual studs you can buy are aftermarket.
    The aftermarket studs are typically grade 10.9, and so torqued up to 140Nm dry or lubricated will always be well below the yield point (between ~50% and ~70% proof load).
    BUT - if the original studs are only grade 8.8 (and this is very possible as this is a more durable grade to use), then 140Nm for a dry connection will take the M14 stud to somewhere around the recommended 75% proof load point. Add a lubricant, the K factor drops, and 140Nm can take it to the yield point - that is you risk stretching the stud. May not fail, but repeatedly done, or over-torqued because you don’t use a torque wrench, and it will eventually snap.
    The LR workshop manual says all bolts and nuts are to be fitted dry “unless stated otherwise”. In this case we have to assume this also applies to wheel nuts as they don’t state otherwise.
    However, if you do add lubricant you should just lower the torque setting to compensate and keep the bolt tension in the optimum 75-90% proof load range (unless you know for a fact they are grade 10.9 studs).
    And if anyone does know for a fact what the original grade the studs are (not aftermarket ones), please post the details.
    Nov 2015
    Black Rock
    [QUOTE=DiscoDB;3195629]Add a lubricant, the K factor drops, and 140Nm can take it to the yield point [QUOTE]
    Can you explain this for numpties? I don't understand how a little bit of lubricant can dramatically affect the yield point.
    2013 D4 expedition equipped
    1966 Army workshop trailer
