Results 1 to 6 of 6
Thread: Stainless Steel Wheel Studs……
    Apr 2019
    Where to source, goggling hasn’t found me a supplier
    Non-land rover application
    I have the need to upgrade from existing aluminum wheel studs to stainless…..
    May 2003
    On The Road
    salt water?
    Apr 2019
    salt water?
    Yep…….On for the hubs on an Amphibious boat.
    Jan 2014
    Perth Western Australia
    *I would find it odd for anything to have aluminium wheel studs.
    *if they are cheap stainless they will still corrode away.
    *if you do get stainless wheel studs, dont use stainless wheel lugs, they will suffer galling.
    *also dont use copper anti-seize on stainless.
    Daz
    Apr 2019
    Quote Originally Posted by DazzaTD5 View Post
    There would be 100’s of these amphibious boats running aluminum studs with aluminum nuts…….
    Our boats would do 10 times the work the most other boat.
    We are already running stainless studs with aluminum nuts….just with a bit of lube, to date they is no corrosion between the two.
    Apr 2019
    Pretty little stud
