Results 1 to 2 of 2
Thread: HPFP change - what else?
    Apr 2010
    sydney
    Hi guys
    The HPFP is getting changed on my 2011 2.7 D4. What else should you do at the same time? 255k on the clock.
    Lucas
    Oct 2012
    Quote Originally Posted by irondoc View Post
    Hi guys
    Lucas
    Oil cooler, plastic water block and even the oil vent seals.
    I’m not sure but you might even gain good access to the vac pump via the empty valley and do that as a common oil leak source.
    Injector return line replacement is a consideration.
    New belt obviously.
    Be prepared for some of those quick disconnect fuel lines to disintegrate. Be gentle.
