Results 1 to 10 of 22
Thread: 300k and the three amigos
    Hi all,
    Just hit 300k on the td5, reconditioned gearbox is going great. But the 3 amigos come to visit. Done the shuttle valve kit and now getting a electrical fault on the abs system (nanocom). If i do the stock 3 amigos wire fix will the abs and traction still work or does it just bypass the lights?
    Thanks all
    Jan 2010
    ABS an TC will still work, you are just bypassing a bad earth in the ABS module.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Thanks mate, is it possible to remove it without removing the entire block? I’m a little nervous in removing the break lines.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by TheEntertainer;[URL="tel:3199626"
    3199626[/URL]]Thanks mate, is it possible to remove it without removing the entire block? I’m a little nervous in removing the break lines.
    Yes, you can access it without undoing the brake lines but you will feel a bit uncomfortable “forcing “ them bending them to reach the shuttle assy.
    I wouldn’t worry too much about undoing the lines if you have access to a NANOCOM or similar. You need one to activate the power bleed program.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jan 2010
    Quote Originally Posted by TheEntertainer View Post
    IIRC I used a very flat ratchet like this to get under the brake line/s or some other obstruction so that I didn't have to take the lines off.
    1999 D2 TD5 Gone
    Jip, got a nanocom, it won’t always talk to the abs module though… reports the electrical fault though when it does connect.
    Sep 2010
    The Hills.
    152.79 MB
    Yes, but it will when you fix it.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Ah so the earth adds to the comms
    Issue. What size Allen key does it take if you can remember. Also how long will
    it approximately take to remove and refit? The electrical will take about 20-30 min all up I recon.
    Sep 2010
    The Hills.
    152.79 MB
    4mm Allen. Call it an hour and a half all up, Land Rover gods willing.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Did the fix but still same issue… tc and abs lights still on error code:
    Shuttle valve electrical switch fail 011 times,
    Grrrr
