Results 1 to 3 of 3
Thread: Charging an older Bluetooth speaker
    May 2003
    On The Road
    This HK speaker works very well...
    but is charged via that old style barrel plug.
    The 240v charger supplies 1A at 19V..
    any clever ideas on how to adapt it to use a normal usb wall socket/cable??
    May 2003
    On The Road
    found this-- I dont want to run it on this cable.. just charge it...
    Mar 2018
    Perth (near Malaga)
    USB-C can do 20V. I have a beaut USB-C cable that does 12V to a 2.1mm barrel connector. You'll probably find an adapter on E-bay. If not, a $2 USB-C 20V trigger board and barrel adapter soldered to it will do the job.
    Edit : USB C PD Type C Male to Male 5.5x2.1mm 5.5x2.5mm 4.8x1.7mm 20V Cable for Routers | eBay
