*might as well replace the rear drive belt for the high pressure fuel pump. (although was it already done at aprox 40K ago?)
*handbrake overhaul kit or maybe just some spray lube down the handbrake cables
*compressor overhaul kit or at least replace the dryer kit.
*lube the turbo actuator linkages
*not related to body off but... if the timing belt was done 40K ago was the top coolant outlet replaced at the same time? if not then do it.
none of the above have to be done with the body off, its just easier.
					 Body off - what opportunistic preventative maintenance?
