Results 1 to 4 of 4
Thread: Territory 2.7 into RRS Which timing belt?
    Gladstone Qld
    Hi All,
    I'm finally at the stage of replacing my RRS 2.7 tdv6 after the spun bearing.
    I have sourced a Territory engine to replace and am at the stage of swapping everything over.
    One question if anyone can help,
    The territory engine is a 2011 which I'm pretty sure is a Euro 4 and my RRS was a euro 3, I see the timing belt
    for a euro 4 is different than to the 3. Which one do I order??
    Cheers Guys
    Jan 2014
    Perth Western Australia
    front belt is the same.
    rear belt:
    *if your rrs is an early one (2005 ish) you have to use your high pressure fuel pump and the mounts, plastic bits, there for use an early belt.
    *you can identify a early engine as there is a short common rail at the back of the engine near the high pressure fuel pump
    *a common rail being like the fuel rail on the side that the injectors connect.
    Daz
    Gladstone Qld
    Quote Originally Posted by DazzaTD5 View Post
    rear belt:
    Thanks Dazza, Much appreciated mate.
    Another Quick one if I may!
    The Territory replacement has a lot more K's than I wanted but all I could afford. It has 280K on the clock.
    The old engine had barley 60K so obviously I will be swapping everything I can from the old engine.
    I was going to leave the heads on and just do stem seals, rocker arms etc. Do you think that's the way to go?
    Should i take the heads off and do a full rebuild while its out? Anything else you could recommend?
    Any advice from anyone would be much appreciated.
    Thanks Again.
    Jan 2014
    While its not a engine i would use on a customers vehicle due to it's high km's.
    If it was my own personal job, I would throw it in and call it done, dont touch the injectors or anything, if you get another 100K out of it I'd be fine with that.
    do the basics:
    timing belts.
    top coolant outlet.
    a few hoses as needed.
    Daz
