As you point out, this is not the original radiator. I do not recognise it. It looks to be designed to have an external pressurised header tank, similar to those used on the later 90/110, or possibly is designed to be unpressurised but only to be filled to the screw thread. As you correctly note, that cap does not provide a pressure seal, but looks to provide a seal between the upper and lower part of the tank - but has an open connection between them through the cap (very strange to me).
The normal operating temperature of the engine (75-80°) does not absolutely require pressurising, but without pressurising will require regular topping up due to evaporation and may boil when worked hard. Remember that this system was designed to use water not 'coolant', and required regular topping up until an unpressurised overflow tank was added in about chassis suffix 'C'.
In my view, while it would be best to change to the correct radiator (but these are very expensive), your current system should remain satisfactory provided that it is checked daily and topped up as necessary. If the level is kept at the threaded bit, there will probably be no overflow. In this case topping up should be with water (preferably distilled or rain water).
