Results 1 to 10 of 11
Thread: Changing a windscreen with a snorkel
    Mar 2016
    Hey all
    Cracked windscreen. I have a Safari snorkel. Does the snorkel need to be removed to change the screen or can they work around it, lifting up the cowling?
    2007 Audi RS4 (B7)
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by DiscoJeffster View Post
    Hey all
    Dunno about a D4, let alone an Audi (), but it wasn't necessary on my D2.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Apr 2012
    Whyalla, SA
    Hey all
    They undo the bolts on the A pillar, pop the cover off and replace as normal.
    Jan 2012
    Hey all
    Depends where you go…some will do as Tombie has written; others will ask you to remove.
    Sep 2014
    Baldivis WA
    Bought my D4 with the safari snorkel, went through 3 windscreens in the time i owned it (9 years 8 months), snorkel never came off.
    Mar 2016
    Cheers all
    2007 Audi RS4 (B7)
    Ocean Reef WA
    Not sure about the 'pop the cover off' when a mob over here did my windscreen a couple of years ago.
    Ripped it off is more the word I would. Bunch of bloody lunatics who advised me not to watch... I think the snorkle side was removed in the same 'couldn't care less fashion it's someone else's property' but I think the snorkles holding bolts have held it in position OK.
    'B' pillar cover kept coming loose and flapping but not actually coming adrift as it was held at the bottom. I fixed it with new clips etc and would never go back to them idiots.
    AlanH.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by ATH View Post
    AlanH.
    Strewth. In my case I was lucky enough to find a small mob recommended as they do a lot of LRs. He warned he might crack the A pillar trim, but he didn't. I would happily recommend them to anyone in Melb's east.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Brisbane,some of the time.
    In my case,they ****ed it up,even without a snorkle.
    Had numerous windscreens fitted to other vehicles by the same mob,no issues.
    Oct 2016
    Perth, AU
    Had mine changed in Perth some years ago - the trim has buzzed in the wind ever since, but a strip of electrical tape to seal it seems to resolve things.
    Also much more streamlined with the tape - I reckon I’ve dropped a few l/100km in fuel burn Changing a windscreen with a snorkel
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
