Results 1 to 4 of 4
Thread: 4 valve or multivalve LPG on a Disco?
    Dalby
    Hi guys.
    I looked at a 1996 Disco on the weekend (same as the one with a funny back seat). It had LPG fitted when it was new so it is due for a retest on the cylinders. I was quoted:
    $260 for a 4 valve
    $360 for a multivalve
    That is per tank so double for the twin tanks (-$50 as still only one certificate).
    Does anyone know if a ten year old system on a Disco is a 4 valve or multivalve system?
    Even if it is only a 4 valve at $470 for a retest then couple that with the possibilty of a $2000 retrofit rebate then it is not really worth anything considering a new system is only $2500. Except that it is already in the car and there is a huge wait for a new system to be fitted at the moment.
    Although for $2500 you get the manifold tank in the back. This is an underfloor system with the 45L petrol tank which I think costs a bit more.
    St Helena,Melbourne
    4.28 MB
    It can be either depending on who made the tanks, if they are APA they will be 4 valve, manchester, C&J will be multivalve. I had mine tested last year for $440 for the pair with multivalves. A new twin tank under floor system will cost over $3000.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dalby
    I rang a few places and they all said they outsource their tank retesting. So I rang an official sounding place in Kippa Ring (Qld) called Gas Cylinder Testing Station and that is what they quoted. So I assume this is where everyone else tanks their tanks to be done.
    Did you remove the tanks yourself? Do they need to be removed?
    I assume the other places don't drive your car to Kippa Ring and back to have the tanks tested.
    St Helena,Melbourne
    4.28 MB
    If you dont remove them they will charge for removal, i swapped mine from another car so they were out anyway. Most places use a mobile tester and the one i used was the cheapest i could find.
    1974 VW Kombi bus
