Supposed to be the RR (Rolls Royce or Range Rover?) of balancers, no complaints about mine.
Hi all has anyone had any experience with ross balancers I have read some on here but would like more up to date on how people have found them I have a Dayco power bond it is on it's way out have a great disliking for anything Dayco. So any help would be great thanks Phil
03 D2a Manual Td5 Modified, Ashcroft lockers F&R, Ashcroft R380,Atb lt230, Ashcroft Rear axles, AS manual IC, AS exhuast manifold, AS Coolant bottle, 3inch exhaust, alive GTB550 VGT, billies 7100s, 3inch lift, 4inch staino snorkel, 35s beadlocked
I have a Ross on mine. Had it for about 5 years now.
Dave.
I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
1983 RR gone (wish I kept it)
1996 TDI ES.
2003 TD5 HSE
1987 Isuzu County
I've just ordered a Ross one, so joining the crew with one very soon!
I have replaced about 15 Harmonic balancers for people so I know it’s a TTY bolt, I do have the tool also to put the correct depth for the timing case seal as well, many people don’t realise that the seal sits in a certain depth
The hub nut is 490nm which is decent but the 750nm W&B torque wrench makes light work of it
Thats a lot! Doing it for first time. I don't have a big torque wrench and hadn't found one, couldn't afford to buy one that does it and tried kennards hire to hire one. They didn't hsve one but awesome fellas there contacted a bus and truck repair place who have one and are going to help me out when the harmonic balancer arrives. They are absolute legends![]()
