There is a Defender loom for sale on Gumtree......Td5 engine wiring harness genuine very good condition | Engine, Engine Parts & Transmission | Gumtree Australia Manly Area - Dee Why | 1313332797
 Master
						Subscriber
						Master
						SubscriberGday All
I seem to remember seeing a post by someone making wiring looms on here?
They were probably for Series Landrovers but thought it worth asking?
After turning my Defender into a submarine, I need to replace all looms and I have a lot of aftermarket electrical gear in it, some of which has been ad hoc.
Alternatively, anyone wrecking a td5 that I can pull all the wiring from? I’m on the NSW Central Coast.
Just trying to make a plan at this stage
You decided to rebuild it then? Have you bought it back? If so would be interested in how that went.
 Master
						Subscriber
						Master
						SubscriberGday Pod
Happy new year and all
Been away camping with v poor mobile reception; it was great!
I can buy my 110 back and she’s not a stat write off, no notification to RMS necessary
I’m still agonising over a decision though
My wife’s not keen and I’m thinking the best idea may be to buy another defender and swap front and rear bars, sliders, roof rack and ladder, water tank, possibly gull wings, rear cabinets, console and tunnel cover, intercooler and rad, possibly suspension, caster corrected arms, and probably other stuff I’ve forgotten.
At least there are some reasonable defenders for sale at reasonable prices (amongst plenty of very overpriced ones!)
I’m considering going back to a 130,
I think radius arms and front prop shaft are same for 110’s and 130’s (?) and most other gear is interchangeable.
It’s still killing me…….
You've probably already investigated this but here's a couple of UK companies that do this.
Wiring Looms and Vehicle Wiring Products | Autosparks
Welcome to British Wiring - classic British car wiring harnesses and components
FWIW my 130 (puma) was drowned in fresh water in 2012 up to the door sill / glass level. I bought it as a repaired/registered write off in 2013 and as of 2024 no adverse symptoms of the flooding from an electrical point of view. other issues but no electrical gremlins that could be explained by the flooding.
MLD
Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
Gone: (Dorothy) MY99 TD5 D110
 Master
						Subscriber
						Master
						SubscriberReally?!
Was she parked up when flooded or driven in?
Did your ecu look like mine, corrosion around all the + outlets/connections and cooked batteries? (My 6 month old yellow top started boiling20 mins after recovery)
Did you have water in the engine?
Mine shows about 4x full level on dipstick…
What did you do to get her running again mate?
 Master
						Subscriber
						Master
						Subscriber| Search AULRO.com ONLY! | Search All the Web! |
