i ran tough dog foam shocks in a 110 and killed them on a trip to the cape.  Replaced with dobinson twin tubes suited for an 80 series (Dobbos equiv to the OME that GL sell).  they were much better.  When i bought the 130 i did the same and fitted 80 series 12" shocks.  they were good for years of outback travel.  I eventually killed them on my second Simpson desert crossing.  Lost all effective compression and rebound.  Replaced them with dobinson 3 way adjustable remote res.  I've done a third Simpson crossing with the remote res and was heavy as all get out (wife packs more than i do when i'm solo).  They controlled the weight nicely and no fade. One thing to consider with the dobbos in the front, the rebound adjustment takes up about 1" of the bottom of the shock, raising the effective bottom out of the shock.  If you fit them, it would be prudent to remove the coil and bottom out the shock and compare to the bump stops.  If necessary, add extended bump stops.  I didn't find the same problem in the rear.
Can't speak for other brands and i'm sure if you had the $$, you would get a better shock from the likes of Radflo, Fox, Bilstein etc.
				MLD
Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
Gone: (Dorothy) MY99 TD5 D110
