Results 1 to 4 of 4
Thread: Pressing bearing etc out. How much force?
    May 2015
    Williamstown, Victoria
    I am looking at a shop press to remove bearings from an LT230 How many tons are needed? Is 6 tons enough?
    Build date 11th Oct 2003
    LROCV #1410
    May 2009
    Tatura, Vic
    6 tons would probably do. But if I was buying a new press I would go for a minimum of 10 tons.
    I have done work on gearboxes where a gear was seized on the mainshaft. I had a 30 ton press and most of this was needed to get the gear off.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    IVe maxed out a 40t press getting some bearings apart...
    typically 20t and a good heat source is enough.
    most 6t pressess will have the grunt but not the room to do the job
    Jan 2011
    Gippsland
    Quote Originally Posted by Bohica View Post
    been there recently - we have a 6 ton press but it was little used during disassembly BUT when it come to assembly the press was used to install the new bearings - and 6 tons was enough for that job. From experience removing old bearings is pretty much always a challenge and in those cases we resort to 'plan B'....
    - cut off roller bearing cage and remove rollers to enable partial cutting of the inner race - see photo. Striking the cut with the chisel cracks the race and allows the race to slide off (inner race of tapered roller bearings).
    - hammer and punch to remove bearing cups - striking from rear of the cup (outer race of tapered roller bearings).
    - used press to remove synchro hub off center diff housing to enable removal of low gear (supported low gear on press base and pressed on center diff shaft to remove the hub and low gear together).
    - used three jaw puller to remove all other press fit items.
    - old bearings together with sockets can be used as press tools to install new bearings.
    NB: I delved into he metal bin and retrieved some examples, the photo is the above method used on some stubborn wheel bearings.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
