Results 1 to 3 of 3
Thread: Mud Flaps Installation (Factory option, but aftermarket) VPLSP0016 / CAS500070PCL
    Jul 2009
    Mid North Coast, NSW
    51.4 KB
    After spotting a L320 in town with what was likely the original factory option fitted and really liked the look and practicality, I looked up in the parts catalog for them and found the numbers and found you could get them 'cheap' on ebay uk. They arrived pretty quick and easy to install:
    Mud Flaps KIT Front & Rear FOR Range Rover Sport VPLSP0016 & CAS500070PCL | eBay
    Just a matter of removing the factory screws and fitting the clips, and screwing back in, dont forget the bottom one underneath (not visible)
    Note the rubber strip, this gets cut in half and is overlapped a little buy the new mud guard
    You will need some longer screws than that you get in the kit for the rear ones
    That black tab folds back on itself to create a spacer, thus the need for longer screws, also the other rear spots fit better with the longer screws
    Note the little square edged notch, just below the screw head at the top there's not a screw here to remove but thats roughly where the top one lines up on the new flap. It didnt come with and more 'nut clips', so i just got a thinner screw and washer and put it through the edge of the plastic fender
    My RRS came standard with rear mudflaps and I purchased a cheap front set off ebay about 8 years ago. The cheap front set have held up as well as the OEM rears in all that time.
    Dec 2011
    Adelaide
    142.79 MB
    Fitted Powerful UK front and rear mudflaps to my RRS today.
    VERY easy job, took about 90 mins.
    Made easier by the videos on their website, and the details on this post.
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
