Results 1 to 10 of 18
Thread: too good to be true? Chain Saw sharpening.
    NavyDiver's Avatar
    NavyDiver is offline Very Very Lucky! Gold Subscriber
    Feb 2010
    My file work is usually good yet a bit slow. I tool to hold the file helps. Saw this on a click bait and had to wonder if its me doing it all wrong or is it just Click bait for the boys?
    (A little battery powered round sharpener is now my tool of choice)
    Pick of the OUT SIdE idea in the link Brains trust thoughts?
    UltraSaw™ - chain sharpener for every chainsaw
    – My-Garden-Oasis.com
    Apr 2011
    Wandong,Victoria,Australia
    Hi,
    I bought something very similar to this. I thought "it's cheap and if it works - then why not! I will give anything a go once."
    Anyway - it didn't fit my saw. The unit that I purchased had a fixed point that you put in the hole at the end of your saw, and it wasn't adjustable.. I had a mate look at it (it case I was missing something) and he agreed - it simply wouldn't work with my chainsaw... In the bin it went.
    Just make sure that it fits is the only advice that I can give...
    Grey Ghost.
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Sep 2010
    The Hills.
    152.79 MB
    If your filing is good enough, then be like your local butcher... if you still have one that is. Notice how every time he goes to cut he will give a couple of passes with his steel. Ok, obviously that would be tedious when chainsawing, but the idea is to not wait until it is blunt before sharpening.
    BTW, I also bought a miracle sharpener. Not quite the same as that one. IMO a total waste of time and money.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    NavyDiver's Avatar
    Feb 2010
    I do have one a little like this with is very quick.
    The file that came with mine was not so good. I cut up a better round file sized specific to my teeth size and that made it work much faster and better Mine is battery powered for remote location use it tended to be used at.
    https://www.amazon.com.au/EzzDoo-Ele...7ef7bd1a5523b4
    Apr 2012
    Whyalla, SA
    My solution was simpler, if not a little more expensive…
    I just fit a new chain and toss the old one
    Apr 2016
    start with a high quality chain which should last longer and won't dull easily.
    Best Chainsaw Chain Brand? (10 BRANDS), Stihl vs Oregon, Husqvarna, Carlton, Forester - YouTube
    Then have a look at his sharpener review too.
    Which Chainsaw Sharpener is Best? Let's find out! Stihl, Granberg, Chicago Electric, Oregon - YouTube
    He picked the two Grandberg tools, and also the Stihl file, which made the chain sharper than a new one, but the Oregon file also did well too.
    Important point in his video for the sharpener is to take time to use the tool 'more correctly' and get ideal grinds for the profile of the chain teeth, and the improvements are noticeable.
    If you don't follow Project Farm, I suggest watch some of his testing vids ...
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Back down the hill.
    I give mine a touch up, with the correct file, every few cuts, more frequently for hardwood, less for for softwood and before packing it up.
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by NavyDiver View Post
    I don't see how that could possibly work. Does it need a special chain? All its going to do is grind the cutters and rakers down , while not sharpening the cutting edge.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Feb 2013
    Ballarat,Vic,Aus
    I like attempting (badly) to file my own. It cuts better than one of the cheap sharpeners.
    This guy is awesome
    Proper cars--
    Modern Junk:
    Jun 2008
    Drouin East, Vic
    I can't see how that gimmick that grinds the outside of the tooth could be any use, even if it did achieve an edge on the first couple of uses, the tooth would be the wrong shape before long and would not be able to be sharpened again without extensive work on the tooth gullet. I'm thinking yes, too good to be true. It will probably do what it is designed to do- sell several thousand units and make money for the designer.
    I've revolutionised my chainsaw experience by learning to use a file properly, after using one of those drop-saw type sharpeners for many years with mixed results.
