Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Detroit Locker Failure
    Feb 2009
    Newborough, VIC
    67.72 MB
    Recently the Detroit Locker that I installed twelve years ago started to clunk violently, a bit more often than it used to, when going around corners. Then last night when leaving my driveway it gave an almighty clunk, then again at the next corner, and the next and so forth, and also sometimes on a straight. It seems that it is the locker that has failed but I understand they are supposed to be bulletproof. So, I was wondering if a broken axle is more likely to be the problem. Has anyone had this issue with Detroits? Is there a way I can tell what's wrong Before I pull everything apart?
    Anyway, I think I know what I'll be doing this weekend.
    2002 D2 4.6L V8 Auto SLS+2" ACE CDL Truetrac(F) Nanocom(V8 only)
    Nov 2015
    Black Rock
    Even if it's a broken axle you'll still need to pull everything apart. 'Seasy to check, just raise each rear wheel and turn it. With a Detroit Locker, it shouldn't rotate. Actually, now I think about it, probably best to raise the rear axle, disengage the handbrake and start rotating prop shaft and wheels to help diagnose. Have a good weekend!
    2013 D4 expedition equipped
    1966 Army workshop trailer
    99.87 MB
    I’m not sure they’re bulletproof. I think in the past they’ve had a reputation for being brittle in many respects and breaking when an axle snaps.
    Hopefully no bits come out with the oil and its just something simple.
    Slunnie
    Back down the hill.
    Is it a locker or unlocker?
    check your flanges first.
    Feb 2009
    Newborough, VIC
    67.72 MB
    It’s an unlocker
    Feb 2009
    Newborough, VIC
    67.72 MB
    Detriot Locker Failure
    Thank you, but what part is the flange.
    My mate reckons simply replacing the oil might fix it but I’m extremely skeptical about that.
    Oh, you mean on the driveshaft don’t you?
    Jul 2011
    Yarrawonga, Vic
    And your still driving it ? After the first unusual clunk I'd have had it up on axle stands and dissasembling till I found the problem, each succesive drive can be adding to the repair bill exponentially. But as suggested probably a flange , that would be a bullet dodged. But If you don't know what part the flange is I think your the wrong guy to be on the spanners.
    And no, your mate is wrong , replacing the oil wont help.
    Quote Originally Posted by biggin View Post
    I ment the axle flanges
    Mar 2007
    Canada
    Disco 2…..
